Reisender
May 23, 2021Nomad
That panel was meant to keep a small charge on your chassis battery. If you can, replace it. The wire terminated up there somewhere. A small 5 or 10 watt panel will be under 50 bucks.
Do you have a solar system for the coach batts?
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
