Reisender
May 23, 2021Nomad
infogeek wrote:
I have no other panels and am not planning on installing any. The wires to the battery are in the AC compartment. The original panel was attached to the top of the AC and the wire went into the AC and out along with the other wire cable for the AC itself.
Just not sure how/where to run the cable without drilling a hole in the roof or air conditioner. Unless I just get a totally different setup.
Well, many just run the wire down the fridge vent. But from there you’ll have to get it to your chassis battery.
If you pull the inside grill off can you see the original wire pair?
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
