Reisender
May 23, 2021Nomad
infogeek wrote:Reisender wrote:
If you pull the inside grill off can you see the original wire pair?
Yes.
Okay. There are probably a couple ways to route that up to the top of the roof from that point. Not knowing your roof or the type of gasket I’m reluctant to advise how to get it back to the outside but a competent tech or maybe someone else on here can help with that. Once it’s outside then it gets easier. Either recycle the original panel or get something small and cheap and mount it on the top of the AC to avoid shadows. Newer panels will be bigger capacity If you go bigger than 15 watts you’ll need a regulator...so don’t. :).
In my opinion you will regret not having that trickle charger on your chassis battery. We added one to every vehicle we had in our squadron in my Air Force days. We never had dead batteries even though some sat for a long time without being used.
JMHO
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
