FastEagle's avatar
FastEagle
RV show info
Here is some feedback from my trip to the Greenville, SC RV show last weekend.
Because I'm a RV trailer tire researcher I paid particular attention to tire/rim fitments on the Cruiser trailers at the show. I also study certification labels for weight correctness and tire fitments to those weights.
All of the cruiser models I looked at had Special Trailer (ST) tires manufactured by West Lake who comes under the Vulcan Tire umbrella. I couldn't find any tire warranty information in any of the owner's manual packages. However, Vulcan says there is a West Lake manufacturer's warranty. More importantly, Vulcan in-house warranty includes road hazards.
In this post I'm just going to address the certification information in the reference below.
Click here to open ref
For me, one of the things that stood right out was the spare tire is identified as a Bias ply tire and the primary tires are Radials. All the models I looked at did in fact have Bias spare tires. Not a big deal because, after all, it's just a spare. You would not want to ride on it very long before replacing it with a radial because it's tread design and internal structure is much different from the highly regarded radials. The Bias tire has stiffer sidewalls and the tread design looks a little like all terrain tires. Oh, none of the spares I looked at were protected from the elements. And, the sales person said the bias spare was used to save end item costs.
According to the certification label, Cruiser RV has not provided very much load capacity reserves with their tire fitment. In this instance it's actually just 20 lbs per tire for the loaded trailer. RV trailers hardly ever carry balanced loads so the possibility of having a tire or two overloaded is very high.
These tire sizes are often very hard to upgrade without having to change rims. There are good options in the 14" size. The Kuhmo 195R14 LRD trailer tire with its European design is almost the same size as the OE Westlake tires and it has 2094# of load capacity at 65 PSI. A much needed increase to get the tire spook out of your rear view mirror.
FastEagle
p.s. The RMA doesn’t have a problem with a bias tire being used as a spare for short term temporary use. The DOT says that OE tires must NOT have more load capacity than the spare tire. A quick check of the load capacities molded into the sidewalls of the primary tires and bias spare reveled that they have equal load capacity.
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
