wgander
Jul 25, 2013Explorer
It's normal.
Your tires might be overinflated for your weight, but that would have more affect on the comfort of your ride than on the swaying.
80 PSI max refers to the maximum air pressure for the maximum load the tire is designed for. Unless you are at maximum weight, you don't need 80 PSI.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
