CA_Traveler
Sep 15, 2021Explorer III
Instead of guessing buy a Kill A Watt and measue your loads in amps or watts which will allow you to isolate the problem to your RV loads or the gen.
First and foremost this is a 1800W or 15A gen. Ignore the 2300W as that is starting amps. Do not expect to run the AC and or the fireplace with other loads as neither of these is a light load.
Also it's a MSW gen and not a PSW gen with is likely causing the TV and perhaps other equipment failures. You probably bought the wrong gen for your application.
