PatrickA51
Apr 16, 2017Explorer
ford-willy wrote:
OK, just got back with the TT from a dry camping Eastern Sierra trip. This one year old 25 ft. TT has all led lighting and I use power sparingly when dry camping. I would run my Honda 2000 for a few hours a day to keep the 2 new large 6v golf cart batteries charged.
So it was cold at night and we set the thermostat to 50 and the battery control panel test light said full charge at bed time. About 1am the forced air starts to cycle on and off about every 1/2 hour. About 3am the Safe T Alert dual propane/Co starts beeping about every 30 seconds or so. That type of beep indicates low supply voltage. So at 3am I am checking the control panel and it says my batteries are at 2/3 full charge. So I check, led lights work, refer is still igniting, water heater ignites, bathroom fan runs full speed. But we could not get this Safe T Alert to stop. Pressed reset button but nothing stopped the beeping. Lost a bunch of sleep.
It must be pretty voltage sensitive. Short of disconnecting it, what else could we be practically doing to solve this problem?????
Isn't it still under Warranty, or did you buy your RV Secondhand?
