wa8yxm
Dec 21, 2017Explorer III
The answer is YES it is safe to splice the wires provided it is done properly.
It is ALWAYS safe to splice wires provided they are not "hot" (that is energized) when you splice them and do it properly.
Use a linesman type splice, not a rat tail and if the splice is exposed to weather use marine grade heat shrink (Get it at a marina) to seal the splice.
note many eo this some put it in the fuel pump lead, some in the starter lead.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
