stew47's avatar
stew47
Sagging headliner
The vinyl and foam headliner started coming down in my 2007 Georgetown. Just in the bedroom in a couple spots. The heat in Ohio has been pretty warm but I can’t imagine that it is the reason. There’s no evidence of moisture. Foam seems fine and vinyl still looks nice. Spray adhesive and stick it back up? What’s good spray adhesive I can buy at Lowe’s or menards?
  • Bumpyroad wrote:
    whatever you use, test a small area first to be sure you have no bleed thru.
    bumpy
    Good thinking
  • whatever you use, test a small area first to be sure you have no bleed thru.
    bumpy
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
