azrving
Sep 06, 2015Explorer
Great price. It's all price vs risk. Some will take abuse beter than others so there are 2 things that I would consider important to do to make it last as long as possible. Number one dont operate at the high end of it's power range. Number two when you are done using it for extended periods, run it out of fuel and put a good shot of seafoam in as it's running out of fuel. This will keep the carb from varnishing. If it has an easy bowl drain all the better but I would still run Seafoam so it goes through the jets. It will not hurt it to have straight seafoam hitting it and sitting in the bowl.
A Honda or a Yammie would probably be most tolerant of running at peak output but that's why they are far more money. Just mentioning for other newer folks.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 07, 2026
