rk911
Mar 25, 2018Explorer
phillyg wrote:
Some do have ice maker problems. However, I found a second water valve behind the drawers to the left of the stove. I didn't check your floorplan so don't know what you've got.
our itssca suncruiser's resi frdge also has a second water valve located in the exterior access panel. that's why i asked if your resi fridge has chilled, filtered water. if that's working AND the bail switch on the ice maker is down then the ice maker itself is likely the problem. othwerwise check the bail switch and your owner's manual for an additional valve.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
