Rollnhome
Oct 27, 2014Explorer
robsouth wrote:
Has it ever worked connected to the "outside"? I'm assuming that you mean a connection on the outside of the camper where one would connect cable TV and in some cases, a satellite dish connection is also available. If not, and you only have a cable TV connection, then it will not work using that connection. It cannot pass thru the rooftop TV antennae connection or a splitter. Let us know how you are coming along with the problem.
I think robsouth has found the problem. I thought the OP was talking about an outside TV but now it makes more sense.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
