chalet05
Oct 27, 2014Explorer
robsouth wrote:
Has it ever worked connected to the "outside"? I'm assuming that you mean a connection on the outside of the camper where one would connect cable TV and in some cases, a satellite dish connection is also available. If not, and you only have a cable TV connection, then it will not work using that connection. It cannot pass thru the rooftop TV antennae connection or a splitter. Let us know how you are coming along with the problem.
You posted while I was typing so apparently hooking to the cable outside connection was not a viable option.
Yes, it has always worked when connected to the outside. Looks more and more like bad coax.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
