Stranger
Oct 28, 2014Explorer
chalet05 wrote:
I have changed nothing.I have changed nothing. I connect the satellite to the port on the outside of the camper. Inside the camper the coax is connected to the port on the wall and then to the in port on the DVR, and the out port is connected to the TV. Somewhere between the outside and the DVR, there is an issue.
Bad coax would make sense. However, I tried changing so satellite was hooked up to what is normally the 'cable' port and had the same results of no satellite found. That cable coax was replaced last year. Yes, I changed the coax connections within the camper as well.
I just wondered if there was some possiblity other than bad coax - not looking forward to going through that hassle again.
Thanks for the replies!
I bolded where you contradict yourself. When this change/repair was made, is it possible you used "new" cable to cable connectors?
If so, it is possible that the connectors you used do not transmit power. DISH needs connectors that have a BLUE insert. The LNB is powered by the "box" if that doesn't happen, you won't get a signal.
At least that's been my experience and what I was told by the tech who fixed a similar problem with my unit.
YMMV
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
