Rygar's avatar
Rygar
Satellite question
Here goes, please, don't flame me if you think I'm an idiot, but, I'm on my way to Florida for the winter. I had Shaw Direct install a satellite system in my fifth wheel. They talked me out of a roof mount with a remote finder. So, I now have a dish on a tripod and I'm having an awful time setting it up when I stop. It's hit and miss whether I can diddle it around enough to find a signal and frankly it's a pain in the backside. So, my question is, can I get a dish in the states installed that is compatible with shaw direct?
  • Yep, level, level, level. Then turn right and left.
    Do use a dishfinder app that will let you see the birds and any thing that might be blockiing it.
  • The most difficult procedure of setting up a tripod is making sure the mast is plumb. Then using a meter to check signal strength. I have found a flat rectangular platform made it easier to level and have the mast plumb.
  • I see that I can buy everything I need from Camping World. I wonder if I should get them to install or buy it and find an installer when I'm parked for a while?
  • Apparently the Winegard Trav'ler is compatible with Shaw Direct. You should be able to get it in the States.
    Me, I use a 75E on a tripod. dishpointer.com is an excellent resource for pointing your Shaw Direct dish.
Having RV issues? Connect with others who have been in your shoes.24,313 PostsLatest Activity: Sep 07, 2025
