Desert_Captain
May 19, 2014Explorer III
timmac wrote:
You have to read the manual, it says for correct fuel millage you need to fill tank and with scan gauge on you enter the miles driven at next fuel up, it needs to be done 2 or 3 times to properly get correct fuel mileage reading, this is how you set up the fuel mileage gauge.
X2 To get accurate readings you need to be consistent as to how full you get the tank. The SC will predict how many gallons it will take and then adjust /correct based upon what you actually fuel and enter into the SC. Mine is usually within a couple of tenths of a gallon if I fill up properly.
Our 2012 24' C V-10 gets between 9-10+ depending on speed, weather and road conditions and I love having trans fluid temps as well.
:C
