smkettner wrote:
2oldman wrote:
Gdetrailer wrote:
Is it a "smart" charger?
Yes it is. Supposedly will never overcharge, and has both a flooded and AGM setting.
I would readily agree with you, except for the part in the manual about not using it as a power supply for a long time. With that in consideration, does that change anything?
Do you have a 24v converter? I would get identical and let them run in series.
Otherwise I would get a 48 volt IOTA.
48 Volt models also available. Call 888-828-1893
Specifically designed to run with or without a battery as a power supply.
Don't forget the IQ controller.
Care needs to be taken when considering putting SWITCHING power supplies in series.. Some power supplies connect the DC "negative" to the AC SAFETY GROUND.. Attempt to run one wired that way in series will result in lots of smoke escaping from your power supplies..
