NinerBikes
Dec 14, 2013Explorer
KATOOM wrote:
Thanks guys.
For clarification.....what I have is a fairly big TH with a couple G27 batteries. I dont remember the RC at the moment but they're the typical marine/deep cell. I plan on adding or changing the battery capacity but thats latter on the list. I'd rather have a solar system in place first which I can build battery capacity from and not the other way around. I have no plans on mounting the panels to the roof either as I want to make them portable so I can park more in the shade and have the panels sitting 50' or so away in the sun light.
I'm still in learning phase of all this but in saying that, I also have no desire to become a proficient professional battery/solar tech either. I just want a simply easy basic setup which works without gobs or modifications and tons of money invested. I'm OK with spending $300-$400 for something like said, and I'd even consider spending up to $500 but much more than that and I feel the cost justification isnt there for what I need.
I've already added a Wave heater to keep any furnace usage at bay, and have even toyed with adding an interior LP lantern too just to lessen battery usage even more. My goal is so my family can spend about a week out in the woods without worrying about the batteries going out. Through the minimal research I've done on this so far I've heard that 100 watts would be OK but 200 watts would really be best and anything over that is kinda an overkill unless I have quite a few batteries and plan on using an inverter often.
Does that help or change anything?
I just went down this road. Two group 27's are about 85 to 90 Ah's each, about 170-180 total. Next time, replace them with some 6 volt 225 ah golf cart batteries and wire them in series, not in parallel.
As for solar panels. You just missed out on Black Friday specials at Solar Blvd with some really good pricing.
My guess is that you'll need about a watt per amp. With portable, you'll need to aim the panels, probably 2 of them 2 or 3 times a day at the sun. You should go with a Poly crystal panel, and I'd go with two 120 watt panels. That should be good for about 15 amps /hr. by about 5 or 6 hours in winter, 12 or more in summer, somewhere in between spring and fall. The last things you need are 12 gauge wire, 50 foot sections, maybe 1 or two of them, to run to a PWM Charge Controller rated for 20 amps, about $20 online on ebay, and the shortest possible run of 6 or 8 gauge wires from the controller, which should be mounted as near to the batteries as possible but not exposed to the vented gasses a charging set of batteries puts off. 3 to 5 feet or 6 or 8 gauge from the controller to the battery, to cut the voltage losses down between the controller and battery. A couple of 100 watt poly crystal or 120 watt poly crystal panels should do it.
http://www.solarblvd.com/Solar-Panels-&-Systems-12-Volt-Solar-Panels/c1_269/index.html?osCsid=177e91ba68387bf12182791233b30bd5
If you kit the pieces together yourself, you'll get a better system. Read up, do searches here, and then decide what is best for you. I am thinking for portability, two 100 to 120 watt panels will do you, 120's if you ride mostly in the winter time when cool with shorter days and less hours to charge up.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
