KATOOM's avatar
KATOOM
School me on these solar packages
I'm trying to do some more research on investing in portable solar panels. From prior discussion I've come to basic feeling that maybe 200 watts sitting in the sun for the day would suffice to offset the average usage night. That said, I've found a couple kits on Amazon I "thought" looked like a good start but I need the input from some of you solar genius boondocking pros. One is a lot more money than the other. Obviously I'd like to spend less if possible. Here's the kits:
http://www.amazon.com/Grape-Solar-GS-200-KIT-200-Watt-Off-Grid/dp/B009ANH7FO/ref=sr_1_11?ie=UTF8&qid=1386822997&sr=8-11&keywords=200+watt+portable+solar+panel
http://www.amazon.com/Basic-Kit-200W-Mono-Controller/dp/B00B8L8MD2/ref=pd_sim_sbs_lg_5
  • Hi Katoom,
    You haven't given us much info about your RV, the space available for mounting a solar panel(s), your battery(ies), or power needs, etc… If you can share some details we may be able to offer an even better solution.
    With regard to the two kits from Amazon:
    - The Grape Solar panels and the Xantrex c35 controller is a very nice combo. IMO, it's a bit too expensive ($/W) for what you get. Do you need an inverter? If so, is a 450W MSW inverter sufficient??
    - The Renogy kit is priced right, but includes a cheap non-programable charge controller.
    If it were me, and 200W met my needs, then I'd consider a single 24V, ~200W panel. Solar Blvd. has panes available for as los as 67¢/Watt. Combine that panel with a SunSaver MPPT-15 and you would have a very nice system for ~$400.
    Cheers
    -Mark
  • The first one has an MSW inverter which I would not personally find suitable.
  • I would get these Solar Cynergy modules and a name brand controller rather than the Amazon offerings. That would be based on a very specific target output of 200w. If you get real lucky, you may able to mount hinges (if necessary) into the modules' existing through holes.
    I chose to use one 235w/24v module and used the module savings difference to buy an MPPT controller with more flexibility and better charge efficiency. FWIW, I spent $360 for MX-Solar 235w module and Morningstar SS MPPT-15 WO/shipping. I also bought the temp compensation cable and the RS-232 interface cable for an additional $60, IIRC. The temp comp interface allows for battery specific charging thresholds, automatically and the RS-232 lets me measure output, log data, and change charge settings through a laptop. This is a larger module that weighs 40lb., not something I would like to lug in and out more than a couple of times. In fact, I wouldn't like to be lugging any modules around but that's just me, more than anything.
    Good luck with the solar, it is one of the more enjoyable modifications and is very reliable. It also seems great for battery health.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
