- theoldwizard1Explorer IIThe most IMPORTANT ingredient in Sea Foam is naphtha ! It is one the only thing that I have ever heard that will dissolve carbon build up on rings. intake valves and in the combustion chamber.
The "urban legend" of Sea Foam is that it was created back shortly after WWII when 2 stroke outboard motor were becoming popular. Back then the quality of the oil was very questionable and some racer used 16:1 ratio. Some even used castor oil (a vegetable oil) ! Such a high amount of oil left carbon deposits o the piston rings and in the ring groves which prevented them from moving.
The whole Sea Foam "process" was to prevent the rings from seizing after heavy use.
2 cycle engines are almost extinct and anyone who really cares about their 2 stroke engine uses synthetic oil anyway.
The IPA in Sea Foam should help remove any moisture in the fuel. The "proper" ratio of gasoline, ethanol and water can cause very serious separation ("layers") of the fuel in the tank. - red31Explorerwhite gas
- MEXICOWANDERERExplorerI tried brewing 50 years ago. Wanted to make money selling it to underage friends. It was soooooo bad...
(Tell Us! Tell Us!)
It made Near Beer taste like Heineken. That's an exaggeration. No liquid on earth would stand a chance against it in the ugly taste department. - DuctapeExplorerI squeeze my own. Direct from snakes that are free range and only eat an organic diet of non-GMO food. I feel all my engines run smoother after a treatment.
And it cures arthritis. :) - MrWizardModeratorway back when.. aka a few years
member Professor95
posted a similar hommebrew mix he used on all the engines on his place
and he has quite a few engines - gboppExplorer
MEXICOWANDERER wrote:
Goes well with being in excess of 70 years of age and being disabled :)
How about using your free time to find us some tips on Homebrew we can drink? :B - MEXICOWANDERERExplorer"You have way too much time on your hands."
Goes well with being in excess of 70 years of age and being disabled :) - agesilausExplorer IIISounds like the author has lab training. I'd give it a try.
- SidecarFlipExplorer III
http://hildstrom.com/projects/seafoam/
You have way too much time on your hands. - path1ExplorerIf I homebrew anything, I won't go in an engine:B
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
