redwake's avatar
redwake
Sealand toilet sticks open
We are camping in San Diego right now and the toilet isn't working right.
After flushing the ball will not close unless I put some gloves on grab it and force it closed. This happens intermittently but certainly enough to be putting a bit of a damper on our trip.
It seems to happen more frequently if we lift the peddle to add water before flushing. It does take a fair amount of force to get it to close.
Any ideas?
  • Valkyriebush wrote:
    There are two screws holding the flush valve/peddle to the toilet, loosen them just a little and try again. That worked on mine. Had a guest almost cause a flood because of this issue.
    This... Well the opposite of.
    A screw came loose. What's really pathetic is it started on our last camping trip and I took the cover off to look at this assembly and did not spot a problem.
    This trip I'll just say I've had to do some pretty drastic things with gloves and a butter life to make sure it flushed.
    That will make you feel like a real tool when you finally take the time to look it over and find a single screw is loose.
    It may actually work better now than when I bought the rig.
  • When we had that problem with our flush valve. I read the manual. They said periodically to lube the valve. I used Vaseline but not that happy with it. Then bought some silicon plumbing grease from hardware store. Put on rubber gloves and the silicon grease solved our problems. I put the grease not only on the plastic but also that rubber gasket.
  • There are two screws holding the flush valve/peddle to the toilet, loosen them just a little and try again. That worked on mine. Had a guest almost cause a flood because of this issue.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
