busyguy wrote:
My Harney coach has the sealed beam headlights. The high beam is great but, the low beam is almost worthless.
I am thinking about changing them to LED's and was wondering if anyone else has already did this. If so how did it work and was there much improvement.
Bulbs are $139.00 a pair on Amazon. Not cheap but may be worth it.
Thanks for your response
Busyguy
Don't bother, those LEDs are for NON SEALED BEAM headlight assemblies AND they are not DOT approved...
There may not be anything wrong with your sealed beams.. What the problem tends to be is to much voltage loss from undersized wire..
Buy or make a headlight relay kit.. Check the voltage at the bulbs, most likely the bulbs are getting 10-11V and should be getting 13.2V or so..
Check the link below for headlight relay kits..
HEREThe link below is an "Instructables" on how to DIY your own relay kit..
HERE
