A few months ago I discovered water soaking the carpet inside a linen closet in the bedroom of my fifth wheel. I dried it out and have since been through several heavy rains with no water intruding. N...
I don't know if it's the best, but I'd use a glop of the favorite RV caulking goo. I usually use OSI Quad as it seems to works well, is not too expensive, and is readily available. The "Max" version is nicer to work with and is claimed to be even better.
Unless the awning power unit moves in operation, I see no reason to provide for more than a nominal amount of give in the wiring.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
