evy's avatar
evy
sealing openings and equipment in outer walls.
Hi everyone,
I'm working on my very first DIY camper conversion, using a 2010 extended Ford E250.
Right now I'm cutting holes on the outside of the van for :
-30 amp main electrical socket
-AC 110v standard outlet
-Water inlet (gravity)
-Water inlet (city)
-Refrigerator lower vent/access
Just to make sure, from what I red on this forum, I disregard the installation manual and I :
-cut the hole
-add grey putty tape
-screw it in place
-silicone around the edge
Don't hesitate if you have any advice at all, thank you!
I just finished cutting this one :
  • Gjac's avatar
    Gjac
    Explorer III
    For what you are doing I would just use the Butyl tape and trim off the excess once you put the screws in. It will not be exposed to UV light so I would not worry about that. Butyl rubber also comes as a caulk. When I worked at Sikorsky that is what we used to seal the airframe structure to prevent water leakage. It also has some adhesive properties but is primarily used as a sealer.
  • I don't recall anybody doing long-term testing, but when silicone is on black list, lot of other caulks can be good for boat applications but will not last long with UV exposure.
    I think Dicor is safest stuff and easy available.
    For interior marine caulks can give you better strength.
    I never liked butyl tape. It is heavy and not a good sealer.
    I think manufacturers like it because of clear appearance, but you don't hear about so many leak problem on RV without a good reason.
  • Almot's avatar
    Almot
    Explorer III
    Lexel (Sashco) clear adhesive caulk. It behaves more like a glue, can be tricky to work with, very stingy and skins fast. Adhesion is excellent.
    There is also Geocel similar to Dicor. Don't remember the name for vertical surfaces, I used it on the roof.
  • Bobbo wrote:
    Don't use silicone. Ever. If you ever have to work on it again, nothing will stick where you used silicone, even more silicone. Get a good exterior non-silicone sealant.
    Dupont 4200 is a very good choice. Be careful though, the Dupont 5200 is permanent. Really, really permanent.
    There is also Dicor. It comes in two flavors, self-leveling and non-self-leveling. Self-leveling is good for horizontal surfaces, like on top of roofs. The non-self-leveling is good for vertical surfaces, like walls.
    BTW, the "grey putty tape" is called butyl tape.
    X2
  • Bobbo's avatar
    Bobbo
    Explorer III
Having RV issues? Connect with others who have been in your shoes.24,299 PostsLatest Activity: Aug 12, 2025
