BFL13
Apr 05, 2014Explorer II
If you go much higher in charging rate than 33% with low batts you don't get any constant amps at all because you are already on the absorption curve.
That is different in a way (it is sort of violent) from using lower amps but starting at a higher SOC where you also would be on the absorption curve right away.
I just prefer having a few minutes of constant amps, then see it taper instead of hitting it with a huge charging rate and getting a monster voltage spike to Vabs right off. Seems too drastic to me. Seeing at least a little constant amps at first makes me think everything is going the way it should.
