Byrogie wrote:
The lever is in the correct position, no green.
Main tank works properly, green when lever to that side. Goes red when empty and switches to secondary. Propane flows from secondary tank ok. Switch lever to secondary side, no green.
Regulator is working properly cause it swaps from empty to full OK
Indicator when moved switches porting from one side to other side.
Side that does not show green (stays red) is plugged
Sometimes.....spraying around the face of lever with WD-40 or Silicone and then exercising lever several times can loosen it up
Otherwise.....live with one side not indicating properly OR replace regulator (even though regulator is functioning---just stuck porting for indicator)
