_DJ_1's avatar
_DJ_1
Explorer II
Jul 28, 2013
Secret Switch?
Looking for some kind of anti theft switch for my F250. Too darn easy to steal!!!!
Any leads would be much appreciated.
Thanks..DJ
  • With this relay installed, the engine will turn over but will NOT START. In my haste a few times over the course of 13 years I have forgotten to click the relay and I know the engine just turns over just does not start. Also imho, any item that will allow the vehicle to run for a few moments will allow the vehicle to be moved out of a parking space to let them load it up on a flatbed. Your choice. I know my system works.
    http://www.emergingent.com/vandalalert/vandal_alert_nostart_99f350ps_installation5.htm
  • Most manual trans. vehicles have a switch on the clutch pedal so you can't start the engine with the clutch engaged, automatics also have the wiring there, just no switch or pedal, just wire in a hidden on/off switch It took 30 minutes to install one on my truck.
    A mechanic friend of mine knew I had a switch hid and still couldn't find it within a half hour. Add a steering wheel club for a visual deterrent so they don't bust the side window, and it will stop 99%+ of the low lifes.
    Don't know anyone who has one.....but lots of folks on the various diesel forums (when there's a thread like this) swear by -
    "Ravelco"
    Also - see the box on the right of the page with info on the number
    one "stolen truck" brand and Revelco's claim to fame.
  • Don'tcha wish you could have a foolproof 480 volt system connected to the steering wheel? Arrests ain't good enough for me - I want burns and scorched hair.
    I get scared when someone says something is foolproof, because in some cases, I can out-goof almost anything. There is always the tried and true shotgun in the steering column, but I'd hate to be alpha/beta testing that out.
    Way back in the past when I had a car that was on the top for thefts, there were four things I did that caused it to stay put. Yes, it did get broken into and the steering column smashed a number of times, but the vehicle stayed put.
    1: I forgot how I did it, but I wired up a DPDT kill switch that would allow the car to start, but as soon as the key was released, the engine would die.
    2: I used a "plain old" Club steering wheel lock. The first models were so easily pickable that it was almost faster to do that than use the key. So, I never bothered locking it, but just sticking it on. To a thief, yes, it was bypass-able, but it meant they actually had a fight on their hands before driving off with their prize.
    3: I added a battery shutoff switch with a removable knob which I pulled off. Yes, this could be bypassed, but it meant popping the hood, etc. This, I wouldn't do on newer cars. Newer BMWs, if they lose battery voltage will have to be hauled into the dealer to be reprogrammed so they would start again.
    4: Absolutely nothing. Thieves forgot how to start cars with carbs. Without pumping the gas, waiting, pumping again, waiting, then starting... the vehicle wouldn't start, period. Too much pumping, and one has a flooded engine. These days, you just turn the key, and vehicle turns the crank the needed amount for you.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
