ktmrfs
Mar 14, 2023Explorer III
yup, as I mentioned in a previous post, the only improvement I would like to see is a way to calibrate the meter for odd shaped tanks. e.g. typical grey/black tanks that have a slopped bottom. calibration assumes a rectangular tank, But then once you have used it a few times, you'll get familiar with it.
It is a well made, well thought out, solution to the factory sensor system.
There is another system (don't remember the name) that let's you do a calibration for odd tanks, but it's much more complex installation, doesn't use the typical facgtory wires, and is even more expensive.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
