MEXICOWANDERER
Sep 12, 2014Explorer
Aha! Says honorable Charlie Chan...
"Busier than one-eyed cat watching three mouse holes"
Big-noses going to re-invent wheel and improve product. One of my improvements is a two dollar bi-directional 180 volt avalanche rectifier that solders any-old-way across the incoming neutral and phase input. Say goodbye to transients and component degradation - this is a PIECE OF CAKE installation since the connectors are exposed.
A .47uf 100 V electrolytic across the output potential should tame some of the ripple.
I was working on my case fabrication until I dropped a glob of molten solder on my big toe. how was I to know I was going to sneeze. Anyway, the shottkey rectifier is now mounted to a 3" X 7" 16 ga aluminum plate. Plastic standoffs to be used to hang from the inside of the roof of the monster.
Next step: Finding that dratted DPDT 26 amp rocker switch. Then a dedicated LED meter and ON-ON switch to select between the 2 outputs to balance the voltages. The finals ammeter - voltmeter is coming next week by burro. Four hour spring wound Intermatic Timer. Relay to NC the float charger. Lots of room for a third CHEAPOWATT. The 300 watt DC to DC converter goes in, set to 16.0 volts. This thing could equalize Mena's L-16's and not even stop yawning. Did I mention the piezo squawker? When the intermatic timer goes to zero a Radio Shack grade doorway greeter is fed from a 1,500 uf cap. Should be good for a dozen annoying electronic ding-dongs.
Ammobox charger never did have any life to the name.
Naw!
This thing....well, it's, it's a...........
BORG CHARGER
Naw!
BORG CHARGER
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
