bighatnohorse's avatar
bighatnohorse
Explorer II
Jun 07, 2022
Self adhesive shower grab bar needed
The shower wall is a textured surface and not suitable for screws.
So I need an adhesive (not the suction cup) type of grab bar.
I was wondering if anyone has done this project and if you found a suitable product?
  • Textured and self adhesive and camper construction do not go together.
    If you need a handle, it needs to be solid.
  • The show is a tiny stand-up-in shower and one side is a flimsy curtain.
    One could fall through the curtain, but not actually "fall down" inside the shower.
    I did read the reviews on the link.
    My hope was someone on this forum already had solved this problem.
  • My shower at home consists of a tub with tile on three sides and a "flimsy curtain" on one side. There is no grab bar nor have I had to have one. Again, what is the "problem"?
  • The only rational way to accomplish a safe surface would need a fascia plate of stainless steel or aluminum that would bankrupt any budget. Exlanation: An outside plate beneath the grab bar that would distribute the pull over a couple of square feet.
    One person has a disability with a sense of balance of about 10-percent.
    That sounds like something more than a grab bar is needed. Perhaps a stool to sit on during the showering. Maybe something like a stainless steel walker to use in the shower. A sturdy door instead of a flimsy curtain. The door might even hold a grab bar. I hope you also have a good, non skid flooring surface or at least a shower mat.
    10% balance sounds really bad--like the need to sit down to take a shower.
  • JimK-NY
    It might be better to ditch the truck camper and get a class-C or something with a more appropriate shower.
    Idk how, but you would need to find some structure (a wall stud) to mount to. And even at that, I wouldn't be super comfortable with, moreso, sinking screws into an already semi fragile structure for this purpose.
    Sorry to hear of the issue, but I can't think of a good solution here. Too many constraints from space to structure, IMO.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
