MEXICOWANDERER
May 16, 2018Explorer
From 30 years ago is valid?
The Dexter units were heavier
But the school of hard knocks taught me this...
Anything threaded or slides or pivots can use an EXTREMELY light costing of anti-seize. Like Never Seize.
Arguments like "Oooooooo no! It'll make brake powder cling!" is irrational. Friction material will grab ahold of bare steel like an adhesive. Anti seize is anti-friction and "brake dust" wipes right off.
Problems with self-adjusters happen when brake dust jams the works causing seizing of parts. I used a clean towel to wipe off all but the thinnest costing of anti seize.
I found zero difference between the two vendors when anti-seize was used. Bare steel the cheaper kit often bent the star wheel lever arm.
Go figure...
Go figure...
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
