time2roll
May 17, 2018Nomad
Passin' Through wrote:The disks just go on direct replacing the drum. Caliper bracket uses the same standard mounting holes as the backing plate. Then a few steel brake lines, rubber brake hoses, T-fittings, and a pump. Maybe a flare tool and you are all set.
.... as well as the fact that I have not been able to find an exact replacement kit to fit my axles.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
