well, he will be alone, and the wife will keep the hearth warm
it is a test of semi-full timing
after a couple of trys, he will learn what works and what he needs more of
but I admit , i don't see many Canucks jumping in and saying yeah we do this, this is how we do it
PT .. you guys are supposed to be pretty hardy, and i take this as a bad sign
not even a Hunter with a winter RV hunting camp has jumped into help out
Huntindog wrote:
pianotuna wrote:
Hi KSG5000,
Sorry non vented combustion heaters are off the menu.
I would consider running a burner on the stove when I was not in the RV, as a blue flame heater.
Remember that a byproduct of burning propane (open flame or non vented) is that it puts moisture in the air. Which will then condense on a cold surface somewhere.
I really don't see how you can pull this off without a generator.
Sure it will be a pain....But there just isn't a easy way to use a RV in those temps.
And ya gotta get it right, whatever you do. When it gets really cold is not the time to discover that some thinking out of the box great idea...Doesn't work as hoped.
