Don,
So .... what have you against two or three of these 6P12 models??:
http://www.ventedcatheater.com/2.htmlYou've praised them plenty of times in the past! I couldn't agree with you more regarding your past accolades on these outstanding RV heaters.
Other than the moisture they might add into the interior (which can be controlled other ways), two or three of these seem like the ultimate interior heating solution for long term very cold dry camping. You could probably even continuously circulate RV interior air heated by these into tank areas to keep tanks unthawed if you don't want to, or can't, use 12V pad tank heaters (which consume about 8 amps each when cycled ON).
Of course two or three of these would cost $1200-$1800.
