CA_Traveler
Dec 31, 2017Explorer III
Three 60 cell 30V panels with 3 bypass diodes in each panel. Each panel can be viewed as composed of 3 subpanels each with a bypass diode. As shown below the output would consist of 20+30+20 = 70V at the given amps. The amps depend upon the given light conditions.
Assuming 8A the output would be 8*70 = 560W for the serial panels. For parallel connected panels the output would be 8*30 = 240W.
With shadows on 7 of the 9 subpanels there would be 8*20 = 160W available for charging with serial panels.
Click For Full-Size Image.
The panel amps will be the full amps for the given light conditions.
A conducting diode will have a small voltage drop (0.3-0.5V) which I have not accounted for.
The right hand red arrow should be on the right hand side along with the shadow...:S
Having RV issues? Connect with others who have been in your shoes.24,262 PostsLatest Activity: Jun 10, 2025
