CA_Traveler
Dec 31, 2017Explorer III
pianotuna wrote:
Then why did 2oldman have the output from his array go down across ALL panels when one cell failed?
Doesn't he have 12V panels? And if so does he have bypass diodes? Regardless there are other possibilities. And is he one of the few 48V battery rigs, not that it's related.
If you place a 6 volt 1 amp-hour battery in series with a 6 volt 240 amp-hour battery the end result is a 12 volt battery with a capacity of 1 amp-hour.
True but not sure of your point.
Perhaps I should have stated that it's a given that serial panels should have the same amp rating. That's analogous to all parallel panels having the same voltage.
And if those batteries were all 1A and one cell shorted then you would still have 1A at 10V. This is analogous to a panel with a conducting bypass diode which represents a short on that panel section. What's reduced is only the voltage and not the amps.
Perhaps we could have a discussion about the pros and cons of opens and shorts for serial and parallel panels? I'm guessing this doesn't happen very often?
Updated
