mountainkowboy's avatar
Dec 07, 2021
Setting up Solar on my Moho
This is my plan;
07 Tiffin 30DA, basically stock with 2 12v 100ah batteries. It had 2 6v's in it when we got it.... but they were toast, and these were almost new and free.
As I understand it... (could be completely wrong) by going to lithium batteries I save weight and get farther draw down than flooded, thus increasing my available ah's.
I plan on running 6 125watt flexible panels on my roof, and replace the batteries, and inverters with newer tech that marries with the solar system. My quandary is do I stay 12 volt and do more batteries. Or bite the bullet and go high voltage trying for better efficiency.
The end goal isn't to be able to reliably boondock and run the coach. I'm not interested in being able to run my roof top AC, I have a gennie if I need it.
  • How much does your Tiffin weigh? I don't think that the savings will matter.
    I would stay away from the flex panels and install 5 or 6 200 watt panels, or 3 350 watt panels.
    I would stay with a 12 volt system.
Having RV issues? Connect with others who have been in your shoes.24,314 PostsLatest Activity: Sep 08, 2025
