CabinetmakerII's avatar
Jul 04, 2016
Sewer odor when towing
We have noticed a strong sewer odor inside our 5th wheel when we stop for a break or to set up for the night. I have checked to ensure there is water in the bottom of the stool that creates the seal as well as placing a seal over the shower drain. I have traveled with the bathroom overhead vent open as well as closed. I have replaced the vacuum break under the bathroom sink. I have not done anything with the rooftop vent caps. I am out of ideas as to what could be causing this problem. Any ideas would be appreciated. Thanks in advance
CM
  • Before you travel, try putting a cup of laundry detergent (liquid) and a cap full of Calgon water softener along with about 5 gallons of fresh water in both black and gray tanks. Sloshing around while you travel will clean out the insides of the tanks and once you arrive at your destination, drain both and rinse out the black. I bet your odor problems will disappear.
    Give it a shot.
    Ron
    CM
    Check them before you give up.
    Sometimes insects can close them off with nests.
    And check under/around other plumbing too.
    What you are smelling could be mold somewhere else.....or a dead rodent. Take out drawers and look under cabinets.
    Inspect little used storage areas.
  • I had this problem once, looked every where, out of being desperate I changed out the seal kit in the toilet ,problem gone. bought a complete toilet rebuild kit sat down on the grass and it took about a hour.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
