mrkoje's avatar
mrkoje
Sewer vent smell - need advice
I am having an issue with sewer odors in my trailer. They seem the strongest around the toilet. I've done some research on here and I think I've narrowed it down to the rooftop vent for the black tank.
Can someone please give me some advice on how I should or could repair this vent. The pictures below are for comparison between the rooftop vent for the gray tank (which looks normal to me) and the broken or incorrectly installed rooftop vent for the black tank.
Here is a picture of the gray tank rooftop vent:
Gray tank (normal looking vent)
Here is a picture of the problem black tank vent. It may be hard to see from the picture but the black hose/pipe that should be above the roofline is approximately 3" below the roofline. It also seems that the vent cover is broken because there is a larger hole here.
Black tank vent (broken or not installed correctly)
Any advice would be appreciated on the repair. I think I will be replacing the cover with one of those 360 degree siphon types that I've read about.
I haven't taken the entire vent cover assembly out yet because of the weather today. I don't have a replacement yet and I didn't want to leave it off over the night.
  • You will need to extend the existing pipe up above the roof.
    Maybe find a pvc pipe that will fit snug into the black pipe.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
