dougrainer
Apr 22, 2014Nomad
The most common problem on the SF series is a bad Hi limit switch. If the Hi limit is stuck open, then the control board will not start the Ignition cycle. Then it shuts off. The Hi limit is the first thing I check and the easiest to access on the inside of the RV. Doug
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
