Lt46's avatar
Lt46
Explorer II
Feb 24, 2020
SF 42 furnace madness
So, turned on heat and got fan but no ignition. Pulled furnace and cleaned, while also doing a tune-up. New sail switch, new overtemp switch, new ignitor and new burner installed. Bench tested 12v + and 12v- connected, jumpered the 2 blue wires and got fan, gas valve click and ignitor sparking. All looks good so far. Re-installed, connected gas line, checked for 12v+ and 12v- at connection and is good, jumpered the 2 blue wires again and the cycle began as expected. Fan operated, click from gas valve and ignition of gas producing heat. Yeah, still good so far. Shut it down and went inside, set thermostat to 90*, set mode on T-stat to HEAT and NOTHING, no fan, no click, no spark, no nothing. What the heck is going on? Further investigation reveals my t-stat will not turn on the AC fan or AC cooling either, no nothing. This is beginning to look like a t-stat failure??? BTW, the 2 amp fuse in the t-sat checked and OK but I put new one in, just to rule it out. Anyone else have any ideas?
Thanks
  • Lt46's avatar
    Lt46
    Explorer II
    Aha, that makes perfect sense and something I have not considered. Thanks very much for the assist.
  • SWAP the blue wires at the furnace connection. Your system probably uses the 12 volt supply from the Furnace to power the wall Tstat and roof AC system. You have the feed side to the tstat on the RETURN voltage side. Doug
  • What he said- swap the wires at the furnace, as one of those supplies power to the thermostat. If you swapped them when you reconnected them, nothing will work.
  • Lt46's avatar
    Lt46
    Explorer II
    Thanks Chris. I have 8 wires coming out of the t-stat with only one blue wire. I'm not understanding what you mean about swapping the blue thermostat wires?
  • Lt46's avatar
    Lt46
    Explorer II
  • Try swapping the blue thermostat wires- one supplies 12 volts to the thermostat.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
