2oldman wrote:
BFL13 wrote:
Which is the Mono? A few years back, you were going to by pass that to see if array performance improved, but didn't want to get on the roof ISTR.
I don't know which is, nor do I remember any conversation about that. Perhaps you can find it. I have never had any issues with getting on my roof, unless I was injured.
Can't find it. You showed a photo of your MH with the panels tilted up, but one was behind another at one end. (not the other photo you showed of it in a parking lot with the back panel shaded) Also a photo of your then new controller display doing its stuff.
The discussion was how jimindenver had reported his mono did not do as well as his poly in low light, so I speculated the mono would pull down the string's amps in the morning and late afternoon. Meanwhile you had a poly being shaded by a panel in front, so I suggested you put that back poly up front instead of the mono and try it with just five polys all up front.
