- NinerBikesExplorerI would get a regular 10w-30 grade full synthetic, since your motor is air cooled, or if you operate in temps below 32F, a 5w-30 grade full synthetic. Probably an SAE SJ gasoline or higher rated grade. You can't really go wrong with a Mobil 1 full synthetic.
I would not run Rotella T1 or T3 diesel straight 30 weight, just because it's cheap, or you found 5 gallons of it on sale. It's on sale because it's not selling, and it's not the very best around. It's not moving, regardless of price. - RJsfishinExplorerRotella T cannot be beat for your generator....no matter what it is. And the 30 wt should be fine too, except in extreme temps, I like multi wt
- westendExplorerIt might shine up the inside of your small engine.......too much. Rotella T has a lot of surfactants and scrubbers and such to keep diesel engines clean. I would follow the Mfg's suggestions for oil.
- Wind_RiverExplorerShell Rotella T Single-Grade Oils are high-quality single-grade oils that are blended to provide excellent performance in diesel engines of many major manufacturers and in many gasoline, LPG or LNG engines (follow the correct performance/viscosity/ temperature guidelines). Additionally, for heavy-duty transmission applications, the SAE 10W and 30 grades meet the performance requirements of Caterpillar TO-2 and Allison's C-4 specification.
