busyguy's avatar
busyguy
shock when touching Rv
I know this has been posted before, just can't find it. I drove the coach this morning for a short drive and when I returned and applied power to it I got shocked when I opened a bay door.
where do I start looking for the problem?
Thanks
Busyguy
  • Your camper is not grounded. Check the connection where you plug in, or the wire from the camper to the plug is broken. More than likely, the wire is broken.
  • You have an open ground in the shore power supply. If the RV chassis were connected to the supply ground then it would not be floating. A floating chassis will adopt a voltage level LESS THEN 1/2 the applied voltage (ie 1/2 x 120 = 60 VAC)
  • I think it's referred to as hot skin. Google that. Try this..
    BTW - googling "hot skin trailer" brings up a whole lot of other stuff not trailer related!
Having RV issues? Connect with others who have been in your shoes.24,285 PostsLatest Activity: Jul 16, 2025
