Hurricaner
Jun 17, 2013Explorer
billyboy wrote:You did not find the problem. The polarity tester might be the leak to ground but if the RV and house is properly grounded you will not get a shock. You still have a bad ground either at the house, RV or somewhere in between with the cords.
I've found that the polarity tester staying plugged in to an outlet was the cause of my getting shocked. took a while to figure it out.
Sam
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
