Hamops
Jun 17, 2013Explorer
The polarity tester can NOT cause the problem. It's telling you that you have a problem. Read the label on the tester and compare the test light configurations. The most likely scenario is that you have a grounded neutral in your trailer somewhere. The neutral is only grounded at the source. ie Pole transformer.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
