billyboy
Jun 22, 2013Explorer
Wayne Dohnal wrote:but I tried a 2nd tester , a hubble tester and it also did the same thing. when I pulled it out I no longer received a shock when outside kneeling on the ground and leaning on the steel part of the frame. the hubble tester was an expensive tester and it showed no abnormal functions.The outlet tester was creating the hazard? That is a new one.An open ground is creating the hazard. The outlet tester is just conducting current to try to light up its hot-to-ground light.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
