kampinguru
Jun 25, 2013Explorer
Harvard wrote:
For sure you have an open ground conductor. In other words, there is no continuity in the ground wire from the RV chassis to the power distribution Earth Grounding Rod. Be very suspicious of the "adaptors".
I would look here as well. I have the same problem when I plug my trailer into the house 110 socket using the dogbone converter. Not a problem any other time, only when using the dogbone. I also get it when I am using my generator to power the trailer due to no ground on the genny.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
