Vic_Bc's avatar
Vic_Bc
Shore power concerns over the winter (new AGM batteries)
Not sure if this is the right forum. I have an old 1990 Dodge Islander which I outfitted about a year ago with a basic solar set up (2x 90W panels and controller)
When I first bought the van it had a small deep cycle for the house batteries. I almost immediately upgraded to two 400aH lifeline 6V AGM batteries. I had bought a converter from bestconverter.com but never ended up installing it as I was always boondocking and the batteries never dipped below 70%. The solar was always trickling so the batteries were charged all the time.
Winter is nigh and now my van is sitting in a driveway waiting to get winterized. I'm still new to the electrical side of things, I have a hard time wrapping my head around it.
My question is this, I want to plug into shore power and run a 1500W heater through the outlets inside. My only concern is overcharging the batteries or messing something up with the electrical current. (winter doesn't get that cold here, maybe -2 Degrees Celsius at the coldest so I was planning on just keeping the batteries hooked up like I did last year and turn the solar on once a month for a few days to charge them up)
What precautions should I take?
  • pianotuna wrote:
    Hi,
    I'd think that with BC power rates it would be better to turn on a heater 24 hours before a trip rather than letting it run.
    I'd allow the solar system to charge the battery bank and leave the breaker for the converter turned off.
    The heater will be on a timer for a few hours a week as it does get a bit moist in my van. I may just run a separate extension cord from the house into the van. As for keeping the batteries charged I'll turn on the solar/controller every month to check the voltage/charge and charge them via the panels as needed.
    I've been told because it doesn't get extremely cold here in BC they are OK staying in the van as long as they stay charged.
  • Hi,
  • No, this is Forum tech support- support for the forum itself. Mod will move it.
    I recommend removing batteries from any cold temps and check voltage every couple weeks.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
