pacamper
Jul 14, 2014Explorer
Question: When you plug into 30 amps at an RV park does it blink or glow steady..
yes, i never saw this light flash at a 30 amp connection at the campground, it always glowed steady, when at home i plug into a normal wall receptacle with an adapter, so maybe thats the issue, its telling me its not seeing 30 amps ?????
Question2/suggestion: Have you plugged in a Kill-A-Watt meter inside, pressed the Volts button and logged the reading, and what is it.
i will check this out today, but i did this in the past and show anywhere between 118 and 122 volts, so that seems ok ??
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
